Drivetrain noise coasting and vibration turning?
2012 GMC TERRAIN
160,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
FGR8FRK
  • 51 POSTS
Drivetrain noise when coasting goes away under load. Noise doesn't change when loading (swerving) left or right. Drove it in circles both left and right in a parking lot and a tight circle produces an audible vibration.
Oct 29, 2023 at 6:19 AM
  • 110,241 POSTS
How would you best describe the noise? Is it loud enough to be recorded and uploaded for me to hear?
Also, have you checked for excessive play in the CV joints? They can cause vibration, noise, and so on as well. Take a look through this link and let me know if anything mirrors what you experienced:
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
Also, and this may sound crazy, but make sure the power steering fluid is clean and full. At low RPMs, it can cause noise and vibration under a load.
Oct 29, 2023 at 12:41 PM
