Broken trans-axle
250 MILES • 3.6L • V6 • 4WD • AUTOMATIC
CEEMUNNY85
XLS model. The trans-axle is broken. is it possible to make it two wheel drive by removing either the front or rear drive shaft and drive it like that until i can have it fixed?
Feb 1, 2019 at 7:10 AM
Good evening.
What do you mean broken?
Is there damage to the case?
Can you post a picture of what you see?
Feb 1, 2019 at 7:23 AM
CEEMUNNY85
It is internal damage all four wheels locked up and then loud grinding noise when i tried to drive. Would not even roll in neutral.
Feb 1, 2019 at 7:58 AM
Okay, thanks.
You need to have it towed to a shop.
Feb 1, 2019 at 9:04 AM
