Driveside taillight-brake light not working?
120,000 MILES • 4.7L • 4WD • AUTOMATIC
ROGUENASHOBA
Just recently my driver side tail light while braking doesn't respond to brake pedal being pushed; turn signals are fine same speed as the as passenger side. the third high brake lamp works & the right passenger side brake lamp works; just not the driver side I tried replacing the pigtail thinking it was a pigtail issue and I still have the same issue.
Jul 23, 2026 at 11:32 AM
  • 55,691 POSTS
You say you did the pigtail but did you do the bulb as well? The first thing I would do is have a helper press on the brake light while you test the wht/tan wire for power, this guide can help you.
https://www.2carpros.com/articles/brake-lights-not-working/
Let me know what you find.
Jul 24, 2026 at 7:10 AM
