Driveshaft the transmission oil seal passenger side
151,000 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
BEN ELVIE BORILLO
The mechanic replace my oil seal between driveshaft and a transmission passenger side and it is still leaking. he said it is inside the housing the transmission needs to come down.
Apr 17, 2017 at 6:59 AM
  • 55,647 POSTS
Hmm,
It is a simple seal and if the housing is damaged to where the seal is leaking ask him to show you where and why the part needs to be replaced.
Best, Ken
Apr 20, 2017 at 4:17 AM
STEVE W.
  • 15,392 POSTS
Unless the bushing inside the end of the housing is bad or the wrong seal was used that side should be simple. Or this is a right hand drive (what country of production) Then the passenger side would be the left side with that long internal shaft and the outer bearing. Still shouldn't be an issue unless the leak is actually a bad case seal.
Apr 21, 2017 at 3:47 PM
