Driveshaft replacement into transmission
164,000 MILES • 3.4L • 4WD • AUTOMATIC
KELLY SHAW FLAGG
  • 6 POSTS
How do I get the ball bearings to stay in place to reinsert driveshaft?
Apr 13, 2019 at 8:56 AM
Good afternoon,
Do you mean the ones in the center support or the ones in the universal joint?
Apr 13, 2019 at 9:02 AM
KELLY SHAW FLAGG
  • 6 POSTS
Goes into transmission.
Apr 13, 2019 at 9:13 AM
Okay, got it.
Is this the joint you are talking about? If it is, why did you remove the boot?
Apr 13, 2019 at 9:19 AM
KELLY SHAW FLAGG
  • 6 POSTS
The boot stayed in the transmission how do I get that out?
Apr 13, 2019 at 9:50 AM
In the picture I sent you, there are bolts you remove for removing the shaft. They are marked number 3 in the diagram. that will separate the joint without removing the boot.
Somebody must have pulled very hard to release that boot.
Apr 13, 2019 at 9:53 AM
KELLY SHAW FLAGG
  • 6 POSTS
The bolts were removed but the boot did not come out, just what I showed you in the picture.
Apr 13, 2019 at 10:06 AM
I never got a picture. Can you resend?
Apr 13, 2019 at 10:18 AM
KELLY SHAW FLAGG
  • 6 POSTS
The second picture is of what stayed in the transmission.
Apr 13, 2019 at 10:26 AM
Okay, there is no service procedure for this constant velocity joint.
Replace the propeller shaft half if any of the following occur:
^ Important: The constant velocity (CV) joint assembly is not serviceable. If the dust boot is torn or the joint is worn or damaged, replace the propeller shaft as an assembly.
Inspect the constant velocity (CV) joint boot for rips or cracks.
^ Rotate the constant velocity (CV) joint to inspect for binding.
^ Inspect the constant velocity (CV) joint for grease or oil leakage.
Apr 13, 2019 at 10:30 AM
KELLY SHAW FLAGG
  • 6 POSTS
Okay, thank you. Now to figure out how to get that piece out of the transmission.
Apr 13, 2019 at 10:42 AM
Use a small hammer. That piece will split in half. You may need a screwdriver to help split the joint. It does not come out of the transmission, it splits past the where the bolts were.
Apr 13, 2019 at 10:52 AM
