Occasionally, I get a clunk on shifting from park to reverse?
197,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
MARKVIII1
No visible play in U-joint when under the car and moving shaft by hand.Occasionally, when starting the engine there is perhaps a one second or less hesitation between cranking and engine turning over, where I can feel what seems like movement of driveshaft (not a clunk).Lastly, have read where a clunk of this nature can be caused by the slip yoke needing internal lubrication of the splines.Thanks so much. Await your thoughts.
May 23, 2021 at 5:08 PM
MOTOR MASTER
  • 279 POSTS
Hello my name is Dave.
As an owner and fan of the VIII your question definitely caught my attention. If the slip yoke was causing this is issue it would most likely need replaced however since it has extremely limited movement it would be unlikely to be the issue. The most common cause of this problem I have found with our cars is in the transmission, the valve bodies of this generation of the 4R70W were not the best and are prone to issues including the chunking you have described, usually going into reverse. If it is intermittent I would recommend servicing the transmission, changing the filter and adding Lucas Stop Slip additive.
May 24, 2021 at 10:07 PM
MARKVIII1
Hi Dave,
Thanks so much for your quick and informative reply. Appreciate it. I will try the Lucas product you suggested. I guess this suggests two more quick questions.
1) Even with the Lucas product, is this a worsening situation, or could it be a fix for very limited driving?
2) Would a new valve body be a more permanent fix for this particular situation, realizing that with a Mark VIII of this age other transmission concerns could come about?
Thanks so much Dave. Look forward to your reply.
May 24, 2021 at 11:33 PM
  • 55,732 POSTS
Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response. Here is how to service the slip yoke which can cause a cluck. This video shows the job being done on a similar car but the process is the same.
https://youtu.be/p2snOCyqVMY
May 25, 2021 at 5:12 AM
MARKVIII1
Can't video a clunk. Need Dave to reply to my reply to his first answer. At that point the conversation was about a possible solution involving the valve body. Awaiting reply.
May 25, 2021 at 7:13 AM
MOTOR MASTER
  • 279 POSTS
Sorry for the delay. A lot of the time the problem is varnishing on the valve causing it to stick and the Lucas is pretty effective at the varnish so if it clears it up it should be a lasting repair. As far as future issues with the transmission they will most likely be valve body related however I don't feel there is enough of a common issue to replace it as a preventive measure. The most common issues are sticking valves and broken accumulator springs, the last one is replaceable without dropping the valve body so is not a terribly extensive repair and usually causes hard shifting which, as a rule won't damage the hard parts of the transmission.
May 31, 2021 at 10:24 PM
