Driveshaft installation
340,000 MILES • V8 • 4WD • AUTOMATIC
CEEBEE TAYLOR
I have purchased the vehicle listed above recently without the rear driveshaft. I have been driving the truck on front driveshaft in four wheel drive high. What all needs to be replaced when I install the new rear driveshaft? It drives pretty good but has started leaking transmission fluid from under transmission not transfer case.
Feb 12, 2018 at 5:52 PM
Good morning.
Are the flanges for mounting the new drive shaft in good condition?
Check the yoke at the differential and the output of the transfer case. if they are good then all you need is the driveshaft and the u bolts to mount it up.
Feb 12, 2018 at 6:47 PM
CEEBEE TAYLOR
Thanks Roy, I really appreciated your help.
I am ordering a new one and new u joints. Have a good one!
Feb 13, 2018 at 7:19 AM
You are welcome.
Feb 13, 2018 at 7:20 AM
