After replacing carrier bearing there is a roaring noise and a vibration
183,000 MILES • 3.4L • V6 • 4WD • AUTOMATIC
JBURTON18
  • 5 POSTS
Removed driveshaft to replace carrier bearing and u-joint put it all back together and when driving it have a roaring noise and a vibration. what could cause this? we heated up slip yoke to get it off to access carrier bearing.
Feb 14, 2019 at 7:17 AM
Good evening,
Does the sound come from the driveshaft area?
Were there any complications assembling it? Did you get the slip yoke to move freely with installation?
Feb 14, 2019 at 7:45 AM
JBURTON18
  • 5 POSTS
Yes, the noise is coming from driveshaft area and the slip yoke I'm referring to doesn't move unless driveshaft does. it's the one at the joint of the driveshafts pieces.
Feb 14, 2019 at 8:06 AM
I know where it is at as I have done many of them.
If the joint does not move freely, it will stress the bearing and cause noise.
If you disable the AWD, does it still make noise?
Feb 14, 2019 at 8:09 AM
JBURTON18
  • 5 POSTS
I removed the driveshaft because I don't know of a way to disable the awd and the noise stops. no when you say move freely what exactly do you mean?
Feb 14, 2019 at 8:10 AM
The slip yoke in the center should slide in and out easily.
If it does not make any noise with the shaft out, you could be getting noise from the rear differential.
You can disable it by disconnecting an ABS sensor. When the ABS light comes on the AWD will be disabled.
Feb 14, 2019 at 8:17 AM
JBURTON18
  • 5 POSTS
My ABS light is on due to a bad sensor. When the driveshaft isn't in it makes noise when it's not it doesn't. the slip yoke doesn't move. is it supposed to like slide in and out?
Feb 14, 2019 at 8:36 AM
Yes it is.
It does sound like you have an issue with the rear differential.
Feb 14, 2019 at 8:39 AM
JBURTON18
  • 5 POSTS
Okay, thank you.
Feb 14, 2019 at 9:04 AM
You are welcome.
Feb 14, 2019 at 9:21 AM
