Driveshaft
82,689 MILES • 2.0L • 4 CYL • AWD • AUTOMATIC
PEGGY ASKME
I had my driveshaft changed Friday. Saturday evening the engine light appears. Only to find out Sunday that I had no oil. I am due for an oil change in fifty miles and I had no oil issues before taking it in. Did they lose oil while changing the driveshaft? Or even transmission fluid?
Aug 27, 2017 at 9:46 AM
HARRY P
  • 2,292 POSTS
They would not have had any reason to drain the oil when changing the driveshaft. So I doubt that they did anything on that end. You probably just have an oil leak. Cap it off, start it up, and let it idle for maybe fifteen minutes. See if you see any oil dripping down. Then let it sit for an hour or two and check again.
Aug 27, 2017 at 12:45 PM
PEGGY ASKME
Thank you. But I had no oil issues before the driveshaft was replaced.
Aug 27, 2017 at 2:21 PM
HARRY P
  • 2,292 POSTS
It has probably been leaking slowly for months. It happens. The driveshaft has nothing to do with engine oil. I promise.
Aug 27, 2017 at 10:23 PM
