Just to jump in, here is a guide that will help with determining if the belt needs to be replaced:
https://www.2carpros.com/articles/how-a-serpentine-belt-works
Plus, here is a video that shows how to check the belt as well:
https://youtu.be/ef3N25wI8uE
Lastly you have a drive belt on the alternator and A/C compressor. Then I show you have a second belt for the power steering.
Take a look below for this info that shows how to remove each belt. There is an adjuster on the alternator and a second on next to the power steering pump.
Please let us know what other questions you have. Thanks
Images (Click to enlarge)
Oct 24, 2021 at 11:38 AM
