Drive (serpentine) belt replacement instructions needed
127,000 MILES • 3.3L • V6 • 4WD • AUTOMATIC
IMAGING
  • 151 POSTS
when replacing the drive (serpentine) for the alternator, should I disconnect the battery terminals. Also, what torque setting is recommended for the bolts to tighten the drive belt.
And lastly, is it easy to install a new drive belt.
Nov 8, 2021 at 4:02 AM
SQM
  • 6,383 POSTS
In order to replace the drive belt, you will have to remove the right hand side wheel as well as the liner inside the fender well to access.
Disconnecting the battery is not necessary.
https://www.2carpros.com/articles/replace-serpentine-belt
I have attached the replacement procedures for both belts as well as all the torque specifications below.
Nov 8, 2021 at 5:22 AM
IMAGING
  • 151 POSTS
in the pic below, under replacement, what is #1 and #2?
Nov 8, 2021 at 12:53 PM
SQM
  • 6,383 POSTS
Number 1 talks about removing the passenger side wheel (you will have to jack up the vehicle and secure it with jack stand).
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Number 2 is for removing the inner fender liner inside the wheel well (see picture below).
Nov 8, 2021 at 2:40 PM
IMAGING
  • 151 POSTS
Can I just lift the hood and loosen the bolts and remove the drive belt?
Nov 8, 2021 at 11:29 PM
SQM
  • 6,383 POSTS
When you access from the top, you might not be able to access the bottom pulleys when installing the new belt. This will prevent you from routing the belt through all the pulleys.
Nov 9, 2021 at 4:15 AM
