Drivers side Brake light out?
138,000 MILES • 2.5L • AUTOMATIC
RACER2711
Driver side brake light doesn't turn on only running light even after changed harness and bulb
Nov 10, 2026 at 11:54 PM
STEVE W.
  • 15,409 POSTS
OK, the description of what you have done points to the bulb socket assembly itself as the problem. To test if it is the issue unplug the connection to the socket, take a simple test light and touch it between pins one and three in the socket (Black wire and Red wire with black stripe) Have someone step on the brake, does it light up? If yes, the socket is bad. Replace it and you should have a working light.
Nov 11, 2026 at 10:05 AM
