Drivers side vent blows hot air with A/C on
110,000 MILES • 4WD • AUTOMATIC
SKINUT20
With A/C on. Passenger side blows cold air, drivers side blows warm air. I found the actuator on the left side of the air box that was not working and replaced it. How do you set the disc that the actuator moves to open and close flaps in the air box? Right now it is still doing the same as before I replaced the actuator.
Feb 12, 2017 at 6:47 AM
HMAC300
  • 48,601 POSTS
pull HVAC fuse inside truck for sixty seconds with key on then reinstall. it should reset of course it should have been lined up prior to install.
Feb 12, 2017 at 7:48 AM
