Drivers side power seat
2006 CHRYSLER PT CRUISER
16,000 MILES
CARHAWK
When trying to move seat forwards or backwards only one side will move. I am trying to remove the seat to check and see if something has jamed the track. I only see 4 nuts holding the seat to the tracs, but after rremoving the nuts it is still attached in the rear, but I cannot see any other bolts or nuts holding it on. Am I going in the correct direction??
May 2, 2013 at 6:50 AM
remove the entire seat and track from the car. then inspect the cable for operation of both tracks together/
roy
May 2, 2013 at 9:21 AM
CARHAWK
This is an electic seat!! Are you saying that I cannot remove the seat from the tracs, I have to remove the entire assembly from the floor??
May 2, 2013 at 9:59 AM
electric??? that new info i did not have.
yes, remove the entire seat so you can turn it over and inspect. plug in the power and see what happens when you operate it.
May 2, 2013 at 10:02 AM
CARHAWK
thanks, Roy
May 2, 2013 at 10:07 AM
