Driver's side parking lamps will not turn off?
12,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
JOHNCBENNETT
  • 5 POSTS
The vehicle listed above is a 3500. Camper van conversion by Thor Industries, designated as a Thor "Sequence 20AT".
I have owned the van for almost two years, no issues. First owner.
The parking lights on the driver's side have come on and will not turn off: The van has been driven regularly, and had been sitting for a few days in our driveway after returning from a multi-day trip. No issues. Last night, we noticed a faint glow from the driver's side, and discovered that both the front and rear parking lights were illuminated. This was not present the night before. We tried starting the van, checking all switches, moving it, but no change. This morning, the lights are still illuminated.
I understand this may be a short in a wiring harness or a bad relay. Any suggestions on where to search or troubleshoot would be very much appreciated. Thank you!
Sep 10, 2023 at 11:25 PM
  • 55,684 POSTS
Yep, this means the BCM is going out. to be sure we should do a CAN scan. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here is how to change the BCM out and its location, you can get a preprogrammed unit by searching Google or Ebay.
Sep 11, 2023 at 11:38 AM
JOHNCBENNETT
  • 5 POSTS
Hi Ken,
Thank you so much for the quick and detailed reply. I will review and try this, and report back. I spent the day today fiddling with batteries, relays and fuses, so this helps immensely.
Sep 11, 2023 at 12:56 PM
  • 55,684 POSTS
You are welcome, please let me know how it goes.
Sep 12, 2023 at 3:04 AM
JOHNCBENNETT
  • 5 POSTS
Hi Ken,
Thank you again for the advice. I've been fiddling with this all week. I picked up a scanner from Amazon, and it found a few issues. The obvious one was:
BCM (Body Control Module - TIPMCGW/FCMCGW)
B11B0-18
Front / Rear Left Parking Lights and Front Left Side Marker - Circuit Current Below Threshold"
So, the BCM knew about the problem! And even stranger, it reported the following four other faults:
B12C7-15 High Beam Right - Circuit Short To Battery Or Open Active
B12C5-15 High Beam Left - Circuit Short To Battery Or Open Active
B12C3-15 Low Beam Right - Circuit Short To Battery Or Open Active
B12C1-15 Low Beam Left - Circuit Short To Battery Or Open
Do you still think the BCM is going out? Or is it accurately reporting something that it sees occurring in the van?
Further piece of the puzzle: The main display on the dashboard also now states "Parking Lights Out" and "Daytime Running Lights Out". I assume those are messages via codes from the BCM.
Of course, it's a bit backwards... the parking lights aren't *out*. They're the opposite of out :).
If you have any further ideas, I would very much appreciate your feedback. Thank you!
John
Sep 17, 2023 at 12:18 AM
  • 55,684 POSTS
I should have had you double check all fuses, please go over this guide to help, if all fuses are good the BCM sounds bad.
Sep 18, 2023 at 4:03 AM
JOHNCBENNETT
  • 5 POSTS
Hi Ken,
Thanks for this... I will go through the fuses one by one. I am now intimately familiar with the location of the three fuse boxes in the van :).
I will report back...
John
Sep 19, 2023 at 2:28 AM
  • 55,684 POSTS
Sounds good, please let me know.
Sep 20, 2023 at 11:02 AM
JOHNCBENNETT
  • 5 POSTS
Ken,
Thank you so much for all your advice. I learned a lot fiddling with this thing!
I've resolved the issue: It turns out it was a faulty trailer harness module that was back feeding power into the lights. I traced the harness wiring to the module and pulled the fuse for it at the battery.
Thanks again for all the advice.
John
Sep 21, 2023 at 7:49 PM
  • 55,684 POSTS
You are welcome, please use 2CarPros anytime we are here to help.
Sep 23, 2023 at 3:48 AM
