Driver's side low beam headlight
2006 CHRYSLER
97,000 MILES • 4 CYL • AUTOMATIC
DEBI BARTLEY
Low beam headlight went out. Replaced the bulb, still not working. Replaced the bulb assembly, still not working. What can it be? Brights work. Passenger side low beam works. This is a PT Cruiser.
Jun 25, 2017 at 2:15 PM
HMAC300
  • 48,601 POSTS
you have not left a model on it, but looking at the diagram it is either a TPIM module which Chrysler has a high failure rate or a can/bus problem . regardless you will need a mechanic to scan for codes to see what the problem is. an auto parts scanner will not work on this must be a professional one.
Jun 26, 2017 at 12:14 AM
