Driver's side heat changes to cold
80,000 MILES
RALPH LASLEY
After about fifteen minutes of driving, all outlets on the left side switch to unheated outside air regardless of temperature setting. It will switch back to warm air for a few minutes after restarting the engine.
For both sides, a setting of 78 gets to about 70. The A/C works okay.
The outside temperature display usually reads much warmer than it is and sometimes rises high then plummets when A/C on. Outside sensor replaced but no change.
Do I need a new main control or just a left blend actuator (and how is that accessed)?
Feb 23, 2019 at 8:51 AM
Good evening,
There is a temperature sensor inside the car which sends a signal to the controller.
The actuator is working as you have cold and heat moving as it should.
I would check the inside temperature sensor.
Feb 23, 2019 at 9:32 AM
RALPH LASLEY
That schematic is of the 2000-5 Deville (my previous car), but I'll try your diagnosis. I know where the sensor is as I vacuumed the lint out of it recently. It's a $25.00 part (now ordered) vs. $250.00 for the controller. Thanks.
Feb 24, 2019 at 9:51 PM
Keep me updated.
Feb 24, 2019 at 9:53 PM
RALPH LASLEY
No luck. The heat turned cold after 23 minutes. Looks like it must be the controller, since the actuator moves, and I assume it could not on its own.
Mar 19, 2019 at 8:35 AM
Did the actuator go back to the cold position when it turned cold?
Mar 19, 2019 at 8:50 AM
