drivers side electric window/mirror switch
51,000 MILES
SIMON HULLEY
drivers side electic mirror/window. The electric window switches are not working. The mirror switches are working. the green led on the window safety switch is not lit. I have checked the fuses reporting to the windows and the wiring conection to the switch unit. This was an intermitent fault but not now. window switches do not work at all.
Apr 18, 2013 at 1:38 AM
what intermittent fault???
did you test fuses and powers with a test light??
Apr 19, 2013 at 8:20 AM
SIMON HULLEY
Tested all fuses. Intermittent fault was the window switches did not work for a day or two then the started ro work again
Apr 19, 2013 at 9:14 PM
