The driver's side door intermittently does not open from the outside?
232,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
TOMJJONAS
  • 10 POSTS
drivers side door sometimes will not open from the outside or inside handle.
Jul 4, 2023 at 8:51 PM
  • 55,748 POSTS
This will be a problem with the latch or the latch adjustment. here is how to replace the latch and do the adjustment to see if it helps. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Jul 5, 2023 at 6:16 AM
TOMJJONAS
  • 10 POSTS
driver side door.
Jul 5, 2023 at 6:17 AM (Merged)
TOMJJONAS
  • 10 POSTS
thanks very much.
Jul 5, 2023 at 7:38 PM
  • 55,748 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Jul 7, 2023 at 2:35 AM
TOMJJONAS
  • 10 POSTS
sometimes my inside or outside door handle will not open i changed the striker bolt and spacer did not work at all my inside door handle will not return to original position for opening the door
it feels like a spring or rod has come loose or unhooked
Jul 7, 2023 at 7:07 AM (Merged)
  • 55,748 POSTS
Did you adjust the striker position?
Jul 7, 2023 at 7:08 AM
TOMJJONAS
  • 10 POSTS
if i adjust the striker plate on my door will this cure my problem of the inside door handle going back to the original open position instead of the extended position?
Jul 8, 2023 at 6:37 AM (Merged)
  • 55,748 POSTS
You loosen the striker by using a TORX bit socket. I believe it is size 35 in the center of the unit, this will help you lower the striker in the jamb which solves the problem.
Jul 8, 2023 at 6:38 AM
