Drivers seat
215,000 MILES • 6 CYL • 2WD • AUTOMATIC
GRIFF22
The switch to move the electric drivers seat is stuck and will not move back. It will go forward, lean forward/backwards and up and down. Is there a way to manually move it back?
Nov 13, 2017 at 9:55 AM
  • 31,937 POSTS
I believe that there is no manual over ride. if the switch is faulty it will have to be replaced.
Nov 13, 2017 at 12:17 PM
STEVE W.
  • 15,385 POSTS
Nope, no manual override on a power seat. If it will not slide it is either a bad switch, bad seat control module or the drive motor has failed.
Nov 15, 2017 at 11:54 AM
