drivers door module replacement does it need to be programmed?
100,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
MAP6912
on the car listed above need to be program to work? i seen on other post you said the 2003 Lincoln town car did have to be i have both years that needs DDM.
Sep 5, 2021 at 6:22 AM
  • 110,248 POSTS
If you replace the DDM, you must first upload the module configuration to the scan tool. Once the new DDM is installed, you download the information to it.
I attached directions below that explain how to replace it.
Let me know if you have questions.
see pics below.
Sep 5, 2021 at 12:39 PM
MAP6912
Thank you, but do you need a special scanner to do this download?
Sep 5, 2021 at 1:27 PM
  • 110,248 POSTS
It will require one that is capable of such communication with the vehicle. A basic scan tool won't do it.
I wish I had better news. Let me know if I can help.
Sep 5, 2021 at 2:18 PM
MAP6912
what kind of scan tool do i need to do this with?
Sep 5, 2021 at 2:42 PM
  • 110,248 POSTS
To do this, you need to have a scan tool that has reprogramming capabilities. Obviously, the OEM scan tool for Fords will do the trick, but they are very expensive. I know that snap-on tools offer scan tools that can do this, but again, they are very expensive.
In this case, you may want to have that part of it done for you. Or, check to see if you are able to find something on Amazon or online that will do the job but won't break the bank.
Sep 6, 2021 at 11:53 AM
MAP6912
lol, got it. thank you
Sep 6, 2021 at 2:29 PM
  • 110,248 POSTS
You're very welcome. If possible, let me know how things turn out for you. I'm interested in knowing. Also, feel free to come back anytime in the future.
Sep 7, 2021 at 11:32 AM
