The driver's door electric lock does not open from the inside?
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
MARCIA ROBERSON
  • 10 POSTS
What should I check?
Sep 29, 2022 at 10:39 AM
  • 110,251 POSTS
Will it open with the key FOB? If it does, then we need to check the switch itself. Do any of the other locks work when you press the lock button on the driver's side?
Sep 29, 2022 at 12:42 PM
