Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Scion
xB
Body
Door
Symptoms
Open
The driver's door electric lock does not open from the inside?
2006 SCION XB
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
MARCIA ROBERSON
MEMBER
What should I check?
Sep 29, 2022 at 10:39 AM
Experienced Mechanic
Will it open with the key FOB? If it does, then we need to check the switch itself. Do any of the other locks work when you press the lock button on the driver's side?
Sep 29, 2022 at 12:42 PM
Add image or video
Ask a new question
Check engine light
Engine won't start
