Where is the driver's side Blend Door Actuator located?
150,000 MILES • 8.1L • V8 • 4WD • AUTOMATIC
NEKO6
My passenger side blows cold; my driver's side is still hot and not controllable. Where is the driver's side blend door actuator located? I've already found the passenger side.
Aug 1, 2025 at 3:20 AM
  • 55,748 POSTS
Yep, this is common problem, here is a guide to help you with the repair and how to calibrate the actuator when the job completed.
Let us know if you need anything else.
Aug 1, 2025 at 5:58 AM
STEVE W.
  • 15,418 POSTS
The left side actuator is mounted on the underside of the HVAC. Remove the trim cover and you will see it. You may need to remove the center console to get to the actuator.
Aug 1, 2025 at 10:23 AM
NEKO6
Thanks. That doesn't look as easy as I hoped but I appreciate it
Aug 3, 2025 at 2:03 PM
STEVE W.
  • 15,418 POSTS
It looks harder than it is. I have done it without pulling the center console but it's a tight fit. The cover is just a flimsy item that hides the molded plastic of the case (and provides a great place for dirt to hide) The actuator is just the screws and electrical plug.
Aug 4, 2025 at 1:45 AM
