driver window will not roll up
130,000 MILES
APRIL PILLAR
driver window will not roll up when I push the button to roll up window, Just rolled down but will not roll up and I can not grab the window with my hand. how do I get the window all the way up manually, so my car is secure from theft
Jul 14, 2013 at 6:11 AM
KHLOW2008
  • 41,812 POSTS
Try banging on the door panel while operating the switch to see if it works.
If it does not work, you would need to remove the door panel to get at the motor.
If the motor is good, manually applying battery voltage to the motor should get it up or down depending on the polarity. You would then need to check the switch and fuses.
If motor is bad, you would need to replace it.
Jul 14, 2013 at 11:01 AM
