Driver window (auto) not work
50 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
SALMAN SABEEH
Hi friends,
I have the vehicle listed above Limited. I shorted the wrong wire to ground trying to fix the door ajar issue. In the wrong happed short in wires.
But I checked fuses 1, 4 and 32 it was fine, so only window drive not work to now, what I do, please?
May 18, 2020 at 9:52 PM
Good morning,
I attached a wire diagram for you to view. The highlighted wire with the circuit breaker is what you need to test for voltage at the master switch or the drivers door switch.
May 18, 2020 at 10:32 PM
