Driver side wiper arm not touching the window
160 MILES • 4.6L • V8 • 2WD • AUTOMATIC
WESTRUCK
  • 55 POSTS
I change wiper blades on my car. I notice the driver side arm is not touching the windshield when the wipers are turn on. The arm is not bent.
Apr 24, 2020 at 11:25 AM
  • 110,248 POSTS
There is a spring on the rear of the wiper arm that keeps pressure on it. Lift and inspect that spring. If it appears good, then chances are the hinge between where it mounts and the arm is corroded and preventing the arm from moving under the spring's power.
If that is the case, lubricate that hing with something like WD40 and work the arm back and forth until it loosens.
Let me know if that helps or if you have other questions,
Apr 24, 2020 at 11:31 AM
WESTRUCK
  • 55 POSTS
Yes the wd40 works.Thanks . Wiper is okay. Take care. From WESTRUCK
Apr 24, 2020 at 11:46 PM
  • 110,248 POSTS
Happy to help. Let us know if you have questions in the future.
Apr 25, 2020 at 3:35 PM
