driver side window/winshield wiper problem
130,000 MILES
THE AUTO FIX
  • 6 POSTS
When i would turn my ignition off my driver side window would still operate for maybe 5-8 seconds. This feature will not operate. Also I installed a windhield wiper motor and the blades will only park in the middle of the winshield. What could cause this problem and how can i rectify this matter.
Jul 4, 2013 at 6:27 AM
FREEMBA
  • 1,152 POSTS
For your windshield wiper problem:
Disconnect the linkage from the motor.
Turn the wipers on and then off after a few seconds. This will allow the motor to go into the PARK position.
Reconnect the linkage.
Operater the wipers to see if this cures the problem.
The window problem :
Are you saying that the drivers side window is supposed to operate for 5-8 seconds after the engine it turned off, but it doesn't; and you want to get it to where it will again?
Jul 4, 2013 at 7:35 AM
