Driver side glass window alignment
180,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
REDCRU777
  • 84 POSTS
I just replaced the driver side glass window, but it's not properly aligned, when closed it leaves a gap at the top near the door center post.
Any suggestion is much appreciated.
Thanks.
Rey
Jan 2, 2020 at 1:55 PM
I assume you have a two door with the floating glass? If so this is pretty common on these doors. I attached the adjustments for the glass. Let me know if you have questions but if you remove the door panel you should see torx screws on the regulator, which are the adjustment screws.
Jan 3, 2020 at 8:19 AM
REDCRU777
  • 84 POSTS
Hi KaseKenny1,
Thanks for this advice and I'm sorry for this delayed reply.
As per your help, I was able to align the glass window on my Neon.
Again, thanks a lot!
Rey
Jan 31, 2020 at 9:09 AM
Thanks for the update. No problem with the delay. We are just glad that you came back and updated us. We love when we get the solution because that will help others that have the similar issue. Please come back to 2CarPros if you need more assistance in the future. Thanks
Jan 31, 2020 at 11:14 AM
