Driver side front tire will not turn
175,000 MILES • 4.6L • 6 CYL • 4WD • AUTOMATIC
LIL J
  • 5 POSTS
Replaced brake hoses on front, bleed brakes, and now as we were driving down the highway. the front left brake locked up! Had to get it towed with a dolly.
Jacked up the front of blazer and took both tires off the front. The tire on the drivers side will not turn (even tried it in neutral), I tried opening the bleeder to see if it would let loose, but it still will not turn. the right side turns just fine in park and in neutral! What could it be or what do i need to check to figure it out? Please help!
Jun 15, 2017 at 4:22 AM
HMAC300
  • 48,601 POSTS
try to take the caliper off to see if it is a brake problem. if the caliper comes off and still will not turn then it is either a wheel bearing problem or an axle/or gear problem inside differential. if you can get the caliper off and it turns then the caliper is not sliding in the bracket or is frozen and you will probably need to rebuild caliper or replace it.
Jun 15, 2017 at 4:59 AM
LIL J
  • 5 POSTS
So i got the caliper off and it still won't turn....how do i figure out if its a wheel bearing problem or axle/gear problem inside differential???
Jun 17, 2017 at 11:18 PM
HMAC300
  • 48,601 POSTS
pull the wheel bearing off or disconnect the axle and slide it out from wheel bearing if wheel bearing turns you know where the problem is. for got is there any fluid in Diff? may not be which I think would help you diagnose this.
Jun 18, 2017 at 12:18 AM
LIL J
  • 5 POSTS
Ok.... so i checked the front diff. fluid and had none! I filled it with 80/90... took almost the whole bottle! I never got a chance to take off the wheel bearing or disconnect the axle before i needed to move the vehicle....i had someone come with a dolly to move it and when we were trying to get it up on the dolly, we discovered that it's no longer locked up?!?!
I've took it around the block a couple times here and there and it seems to b fine but I've never taken it any further!! One thing that is different is now my 4x4 won't engage when i push the button... it worked b4 all this happened! Just wondering wat i need to fix or is it gonna lock up again if i drive it or could it just have been that there was no fluid in diff., etc??? Any ideas?
Jul 2, 2017 at 11:29 AM
HMAC300
  • 48,601 POSTS
scan for codes if any but sounds like the diff has something seriously wrong. try driving short distances less than 5 miles it may free up by getting lube.
Jul 2, 2017 at 11:22 PM
LIL J
  • 5 POSTS
I just drove it 30-40 miles at up to 50mph and it was fine except a chirping sound
Jul 3, 2017 at 1:34 AM
HMAC300
  • 48,601 POSTS
does the 4wd work now? I tmay be because it wasn't full of lube if you were down a quart it's leaking someplace so find the leak and fix it as well.
Jul 3, 2017 at 2:27 AM
LIL J
  • 5 POSTS
It didn't work when i tried it and i haven't even tried it again yet so I'm not sure!!
Jul 6, 2017 at 9:15 AM
