Driver Side - Front Left Door - Body Side Molding Removal
140,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
B767_400
  • 36 POSTS
Need to remove the Driver Door Body Side Molding due to some rust on the lower edge of the Molding.
Do I need to remove the inner door panel as well to release some clips, or is the molding just glued on?
Thanks
Aug 24, 2025 at 7:41 AM
  • 55,743 POSTS
The side moldings on these cars were installed with double-sided automotive tape (3M foam adhesive tape) from the factory.
Aug 25, 2025 at 2:48 AM
