My driver side door is stuck, I cannot open it from the outside or inside. how do I remove the panel to to get it open to fix it?
Sep 3, 2017 at 12:56 PM
✓Experienced Mechanic
It sounds like the latch is jammed here is a guide to help you get the door panel off, it might be better if you removed the seats so you can get in there.
