Driver side door
123,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
WGW_1725
My driver side door is stuck, I cannot open it from the outside or inside. how do I remove the panel to to get it open to fix it?
Sep 3, 2017 at 12:56 PM
  • 55,721 POSTS
It sounds like the latch is jammed here is a guide to help you get the door panel off, it might be better if you removed the seats so you can get in there.
https://www.2carpros.com/articles/door-panel-removal
Cheers, Ken
Sep 5, 2017 at 8:00 AM
