Driver side brake light not working
1998 CHRYSLER CIRRUS
95,000 MILES • 2.8L • 6 CYL • 2WD • AUTOMATIC
BOBBY RUSH
Every thing else is fine. Even turn signal and tail light. Replaced every thing except relay.
Jul 13, 2017 at 3:37 AM
CARADIODOC
  • 34,381 POSTS
Since the right side is working, there is not much that can go wrong on the left side. Terminal six should have a pair of white/tan wires. One goes to the right side, so we know the twelve volts is making it that far. Look at the pins of that connector. If they are soldered to a circuit board, look for bad solder connections. If that is a flexible plastic overlay, those often develop breaks in the copper traces. Remove the brake light bulb, then check for twelve volts that shows up on one terminal in the socket when a helper pushes the brake pedal. If that twelve volts does not show up, see if you can find the break in the circuit. If it is inside that flexible plastic, you may be able to solve this by running a jumper wire between the bulb's socket and the assembly's connector.
Jul 13, 2017 at 12:59 PM
BOBBY RUSH
Thank you for responding
Jul 15, 2017 at 3:25 PM
  • 55,421 POSTS
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
Jul 17, 2017 at 6:02 AM
