driver side blows hot passenger blows cold
2009 FORD TAURUS
160,000 MILES • 3.5L • 6 CYL • AUTOMATIC
BYRONJB804
driver side blows hot and the passenger side blows cold. I changed the blend door actuators and still the same thing. help!
Nov 15, 2016 at 4:34 AM
JIS001
  • 3,412 POSTS
First thing you need to do is have the A/C system level checked. If you are low on refrigerant it will give you the symptom you are describing.
Nov 15, 2016 at 6:23 AM
