Driver side blows cold air on all modes
115,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
BRANDON2233
On all modes, HVAC blows cold when supposed to be hot or warm on driver side.
Where is the actuator?
Thanks!
Dec 1, 2020 at 3:48 AM
  • 110,248 POSTS
It does sound like the blend air door actuator. There are two on this vehicle. The right side is likely bad.
Here is a link showing how in general to replace one:
Here are the directions for replacement. The attached pics correlate with the directions. Note that in pic 1, I highlighted the actuator.
_______________________________
2008 Chevy Truck TrailBlazer 4WD V8-5.3L
Air Temperature Actuator Replacement - Right Side
Vehicle Heating and Air Conditioning Air Door Actuator / Motor Service and Repair Removal and Replacement HVAC - Manual Air Temperature Actuator Replacement - Right Side
AIR TEMPERATURE ACTUATOR REPLACEMENT - RIGHT SIDE
Removal Procedure
1. Remove the I/P carrier.
see pic 1
2. Remove the right side air temperature actuator retaining screws.
3. Disconnect the right side air temperature actuator electrical connector.
4. Remove the right side air temperature actuator.
Installation Procedure
see pic 2
1. Install the right side air temperature actuator.
Notice: Refer to Fastener Notice.
2. Install the right side air temperature actuator retaining screws.
Tighten the screws to 1.9 N.m (17 lb in).
3. Connect the right side air temperature actuator electrical connector.
4. Install the I/P carrier.
5. Recalibrate the air temperature actuator on vehicles equipped with automatic climate control (C68). Refer to Actuator Recalibration. See: Vehicle > Programming and Relearning
Let me know if this helps.
Dec 1, 2020 at 9:53 AM
