How do I remove the top left screw on the driver side blend door?
90,000 MILES
2016FUSION
Driver side blend door.
Dec 26, 2022 at 10:51 AM
  • 110,251 POSTS
The accelerator pedal needs to be removed to gain access. If you look below, I attached the directions for the replacement of the actuator. See pics 1, 2, and 3.
Starting with picture 4 are the directions for removing and replacing the accelerator pedal assembly.
joe
Dec 26, 2022 at 2:18 PM
