Driver Seat Heat turns self on
106,000 MILES • 6.0L • V8 • AWD • AUTOMATIC
04ESCESV
The driver's seat heat turns on by itself. I can turn it off but it soon turns back on. This started recently, but is getting progressively worse. Only driver seat is not working right.
On/Off is indicated by heat at my back and lights on driver's door seat heat controls/indicators.
If repair will be expensive ($200.00) I would prefer to disconnect it, but I do not know how.
Aug 17, 2016 at 12:38 AM
HMAC300
  • 48,601 POSTS
first thing is it will have to scanned for codes to see if anything is wrong with it. It may need a re-calibration to fix it. until that is done you cannot put a money figure on it. you would have to remove door panel and disconnect the switch then neither seat will work.
Aug 17, 2016 at 3:01 AM
