The driver's power door lock works perfectly; however, I cannot manually unlock the door from the inside of the car. Key, fob, exterior/interior buttons all work fine. If I park car with door locked while running it should unlock when car is shut off and I pull on interior door handle, but handle will not budge to unlock door. A vertical door lock shaft near the window also will not budge to unlock door. Not actuator, nothing appears to be loose inside door.
Mar 30, 2022 at 9:47 AM
