Driver Information Center error codes and electrical issues
1994 OLDSMOBILE 88
125,000 MILES • 3.8L • V6 • FWD • AUTOMATIC
ANTHONY R S
My Eighty Eight Royale LS is having some trouble being a reliable car. Wonderful to drive when it works, but its undrivable as it is now.
It has a control pannel, (shown in pictures with the error and code for it) very helpful, but when i rev the car (driving or parked) to about 1400rpm then quickly release the pedal, the revs drop down to 200rpm and it stalls. Then it starts dinging and that message shows. There are some other problems with the vehicle, but those are obvious and aren't electrical, such as an inch of oil sitting on top of the engine coolant (most likely from a faulty head gasket?) and a scraping noise while using the extremely worn brakes.
Any help and information you have on problems such as these would be extremely helpful, but i really need help figuring out what is causing the stalling.
Jun 30, 2015 at 4:09 AM
WRENCHTECH
  • 20,761 POSTS
You have oil in the coolant and grinding brakes. sounds like it's time to retire that car.
Jun 30, 2015 at 4:33 AM
ANTHONY R S
And if that isn't an option?
Jun 30, 2015 at 10:47 AM
WRENCHTECH
  • 20,761 POSTS
If it's not an option you will spend more money than that car is worth.You can start by looking for another engine and spending a few hundred on the brakes. If you don't plan on doing it, then you need to just park it until it's saft enough to drive.
Jun 30, 2015 at 10:51 AM
ANTHONY R S
So theres nothing you can tell me about the problems ive been having with it stalling?
Jun 30, 2015 at 11:01 AM
