Driver's door will not open
130,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
CHARLIE1986
Hi all,
The door on my car is locked and i cannot open it from outside or inside, both of the handles look too loose. Everything I check on internet gives you the solution only if is open the door already but if is close i cannot find anything. Can you help any advise?
Jan 11, 2018 at 7:12 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
If you cannot remove the door panel with the door closed in order to take a look inside that door to find out what is wrong, maybe removing the seats if you have to then it appears that you are going to have to get the door open and perhaps you can get it open with the use of a slim-jim, a thin tool used for opening car locks.
Here is an example of a slim-jim:
http://www.autobodydepot.com/AET-SJ2.html?gclid=EAIaIQobChMI-OCC1NvS2AIVxEoNCh3Gtw00EAQYAiABEgIbGPD_BwE#.WljRAEly6Hs
Jan 11, 2018 at 11:15 PM
CHARLIE1986
Thanks for the tip. I will have a go and see what I can do. I removed the panel but is still the one holding the window. all look okay until now so I suppose is inside.
Jan 11, 2018 at 11:29 PM
  • 55,721 POSTS
I would try and look to see if the control rods are connected the the latch. Can you upload a picture if the inside of the latch since the door panel is off? I am thinking you can work the release of the latch using a long standard screwdriver. Can you double check the year I don't see it in out database?
Jan 15, 2018 at 7:09 AM
TIM TINDALL
Hi Ken. Got same problem with my 1997 fiesta flight. Managed to get door panel off from the inside but all the mechanism is covered with plastic or steel. Interested in your long screw driver method. Where do I poke it ?
Regards,
Tim.
Dec 11, 2018 at 8:24 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Tim,
You should open a new post for this.
Dec 12, 2018 at 12:04 AM
TIM TINDALL
How do I open a new post ?
Dec 12, 2018 at 1:54 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Dec 12, 2018 at 2:16 AM
