Driver Door Module - Power Windows
154,000 MILES • 6 CYL • 4WD • AUTOMATIC
MATTMANTAN
  • 5 POSTS
On the Driver side door module panel where I can control all the power windows & locks of the vehicle, the power window function doesn't work. As in, I cannot roll down my window or any others - However, I am still able to lock & unlock all locks from this panel, as well as use the disable passengers from rolling down their windows feature.
What could be the problem? Fuse, Power window motor?
Thank you, I will donate if I receive the solution.
Thank you very much I appreciate it!!
Aug 20, 2015 at 12:59 AM
HMAC300
  • 48,601 POSTS
check fuse and breakers in pic then have it scanned for codes may be the body or driver door module or drivers switch
Aug 21, 2015 at 12:56 AM
MATTMANTAN
  • 5 POSTS
Thank you Sir Very much for the help!! I GREATLY appreciate that!!
Aug 21, 2015 at 1:02 AM
