Driving rough when accelerating
11,905 MILES • 1.9L • TURBO • 2WD • MANUAL
JAMES212
Drove to shop van cut out engine failure light come up on dash. later to find battery cable was disconnected. so reconnect start back since then lights are all gone off dash, but vans been driven very bad like need good service driving rough. took it to local garage they put the computer on it 6 codes come up, but he restore them said was fine. but still no different?
Apr 15, 2019 at 5:28 PM
  • 110,248 POSTS
Welcome to 2CarPros.
First, this vehicle isn't offered in the US, so my technical information is limited. However, six codes don't come up for nothing. I would need to know the codes that were found. Also, just clearing the trouble codes doesn't fix a problem.
If you could, let me know what codes were found so I can better direct you. Here is a quick video showing how to retrieve codes:
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner, but often times parts stores will lend or rent one to you. If the light has come back on, re-scan the computer and let me know what you find.
Apr 16, 2019 at 3:10 AM
JAMES212
Sorry it’s done 111900.
Apr 16, 2019 at 4:16 AM
  • 110,248 POSTS
Regardless of the mileage, we still need the trouble codes. Are you able to get them?
Apr 16, 2019 at 8:42 AM
