drive with piston ring damage
7,456,554 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
PORTGAS D ACE
  • 28 POSTS
The piston ring for the fourth cylinder is damaged, meaning it gives a (pressure) bigger than the other cylinders, but it does not have blue smoke from the exhaust and has a leak of (coolant) from one of the freeze plug. Is it good and safe to drive it for 400 km or more in a Hight way road? please answer..
Mar 18, 2021 at 8:23 AM
Good morning,
I would not drive it that distance at all. It could very well cause more damage and end up leaving you stranded on the road.
I attached a picture for you of the breakdown of the piston below.
CAUTION:
Apply new engine oil to parts marked in illustration before installation.
DISASSEMBLY
1. Remove the engine and transaxle as an assembly from the vehicle, and separate the transaxle from the engine. Refer to See: Engine > Removal and Replacement.
2. Mount the engine on a suitable engine stand.
3. Drain any remaining engine oil and coolant from the engine.
4. Remove the following components and associated parts.
- Exhaust manifold and three way catalyst assembly. Refer to See: Catalytic Converter > Removal and Replacement.
- Intake manifold collector. Refer to See: Intake Manifold > Removal and Replacement > Intake Manifold.
- Intake manifold and fuel tube assembly. Refer to See: Intake Manifold > Removal and Replacement > Intake Manifold.
- Ignition coils. Refer to See: Ignition Coil > Removal and Replacement > Removal and Installation.
- Rocker cover. Refer to See: Valve Cover > Removal and Replacement > Removal and Installation.
- Front cover, timing chain, and balancer unit. Refer to See: Timing Chain > Removal and Replacement.
- Cylinder head. Refer to See: Cylinder Head Assembly > Removal and Replacement.
5. Remove the knock sensor.
CAUTION:
Carefully handle the sensor and do not drop the sensor.
6. Remove crankshaft position sensor (POS).
CAUTION:
- Avoid impacts such as a dropping.
- Do not disassemble.
- Keep it away from metal particles.
- Do not place sensor close to magnetic materials.
7. Remove the flywheel (M/T models) or drive plate (CVT models).
Hold the crankshaft with a stopper plate and use a suitable tool to remove the bolts.
CAUTION:
- Be careful not to damage the flywheel contact surface for the clutch disc.
NOTE:
- The flywheel two-block construction allows movement in response to transmission side pressure, or when twisted in its rotational direction, therefore, some amount of noise is normal.
8. Remove pilot converter using Tool (CVT models).
Tool Number : ST16610001 (J-23907)
9. Remove the piston and connecting rod assemblies.
a. Position the crankshaft and corresponding connecting rod, to be removed, to the bottom dead center stroke.
b. Remove the connecting rod cap. Number the cap so it can be assembled in the same position.
c. Using a hammer handle or similar tool, push the piston and connecting rod assembly out of the top of the cylinder block. Number the piston and rod so it can be assembled in the same position.
- Before removing the piston and connecting rod assembly, check the connecting rod side clearance. Refer to See: Cylinder Block Assembly > Overhaul > Inspection.
10. Remove the connecting rod bearings. If reusing, number them so they can be assembled in the same position and direction.
CAUTION:
- When removing them, note the installation position. Keep them in the correct order.
11. Remove the piston rings from the piston.
- Use a piston ring expander.
- Before removing the piston rings, check the piston ring side clearance. Refer to See: Cylinder Block Assembly > Overhaul > Inspection.
CAUTION:
- When removing the piston rings, be careful not to damage the piston.
- Be careful not to damage piston rings by expanding them excessively, if reusing them.
12. Remove the piston from the connecting rod as follows.
a. Using a snap ring pliers, remove the two snap rings.
b. Heat the piston to 60 - 70 C (140 - 158 F) with a heat gun, or equivalent.
c. Push out piston pin with a punch of an outer diameter of approximately 19 mm (0.75 in).
Mar 18, 2021 at 7:15 PM
PORTGAS D ACE
  • 28 POSTS
what kind of damage? can you explain more please?
Mar 18, 2021 at 8:53 PM
To the engine block itself. The piston could fracture and seize the engine.
Mar 18, 2021 at 9:08 PM
PORTGAS D ACE
  • 28 POSTS
what if I drive slowly and at low rpm??? please answer.
Mar 18, 2021 at 9:19 PM
Same answer. Any type of driving can cause catastrophic damage.
Mar 18, 2021 at 11:37 PM
