Hello, I’ve just replaced my front differential and transfer case on my vehicle listed above because of a loud clunk noise from the transfer case and humming noise with metal shaving from front differential. I’m now having a binding noise when I have a hard acceleration rite in front of the transfer case. Took it to a mechanic and he says it’s binding at the transfer case. It only occurs when I accelerate from stop, but if I take off slow, no pop is present. I noticed the oil pan also twists on the driver's side when all of that happens. I was thinking motor mount might be bad. I’ve already changed out the u-joints, but not the drive shaft. I’m also getting vibration in the driveline when accelerating until around 45 MPH then it stops. I’ve replaced the rear yoke with a nickel-plated yoke.
Apr 26, 2022 at 10:05 AM
