Vibration in fourth and fifth gear
408,000 MILES • 3.4L • 6 CYL • 4WD • MANUAL
VICKIE JARRELLS
Started vibrating in fourth and fifth gear at a pull not when clutch pushed in. Had original clutch so I had it changed did not help. Took drive shaft to have balanced, it was fine, changed carrier betting did not help.
Jan 13, 2020 at 5:46 AM
BMDOUBLE
  • 1,139 POSTS
I've had faulty coils, plugs, and wires cause issues that feel exactly like a driveline vibration, I mean exactly! And it would only present itself at highway speeds in 4th and 5th gears because that is the point of highest load.
Jan 13, 2020 at 9:14 AM
