I wish to change my propeller shafts sliding joint so it can be direct with out the sliding joint.
Jan 31, 2020 at 7:10 AM
STEVE W.
✓Experienced Mechanic
The slip joint is there to allow the suspension to work. Because of the design the shaft has to expand and retract to allow that. Without it the shaft will get damaged from the forces on it.
