Drive Side Tail Light
210,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
HUNTER GLAVIN
So on my K1500 my tail light first did not light up when the brakes where applied. All the other lights worked fine. And after a couple of days after which I replaced the circuit board for the tail light, now all three lights have stopped working and my turn signal acts like a little kid who stutters. Need help please!
Mar 15, 2017 at 12:22 PM
HMAC300
  • 48,601 POSTS
check the ground at left hand rear of frame it may be corroded or broken off clean it and then see what happens. then if you have had a trailer plug installed check that for connections as a lot of problem appear due to the cheap connectors they use causing broken wires to lights.
Mar 16, 2017 at 12:16 AM
