Drive shaft
100,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
LLOYD'S
  • 5 POSTS
Cannot get the drive shaft back in place.
Sep 30, 2017 at 11:16 AM
  • 31,937 POSTS
Are these replacement shafts or the shafts that you removed?
Sep 30, 2017 at 4:47 PM
LLOYD'S
  • 5 POSTS
Replace shaft.
Sep 30, 2017 at 5:17 PM
  • 31,937 POSTS
have you checked the the spline count is correct and the diameter of the shaft is the same?
Sep 30, 2017 at 5:30 PM
LLOYD'S
  • 5 POSTS
Everything is the same.
Sep 30, 2017 at 5:31 PM
  • 31,937 POSTS
then alignment is a problem and may be the retainer clip is very tight and not compressing easily to enter the splines.
Sep 30, 2017 at 5:45 PM
LLOYD'S
  • 5 POSTS
I think that is it also.
Sep 30, 2017 at 5:47 PM
LLOYD'S
  • 5 POSTS
Will try it in the morning.
Sep 30, 2017 at 5:48 PM
