Drive shaft seal leak
130,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
JUSTYN
Hi there,
I have a leak in my transfer case right where the drive shaft goes into it.
I had some bad u-joints and replaced them but it seems to be leaking oil from this location.
Any ideas?
I had a couple replies on my thread at http://fixamotor.com/forum
but still have not managed to quite figure it out.
any input would be greatly appreciated.
thanks,
Justyn
May 7, 2017 at 10:12 PM
HMAC300
  • 48,601 POSTS
it is probably the seal is bad on t-case if you replaced it and did not lube it up prior to reinstalling shaft then it burnt it up and it leaks. Or the bearing/busing in back is worn out and causing it to leak.
May 7, 2017 at 11:58 PM
JUSTYN
Ok perfect, I thought that's what it was but just wanted to be sure.
thanks a lot for your help
justyn
May 8, 2017 at 9:36 AM
  • 55,770 POSTS
Please use 2CarPros anytime, we are here to help and tell a friend.
Cheers, Ken
May 11, 2017 at 4:16 AM
